Is there a way to select text or anything else within a group? If I have a larger grouping that includes text can I select the text without ungrouping? In Coreldraw if items are grouped you can select the component you want text or anything by holding the “shift” key then selecting. Is there a way to do this in LB? Thank you,
It does not work in Lightburn, you must first open that group /ungroup to be able to select the text
This seems like something that can be changed fairly easily. I have a bunch of files that have multiple groupings that are very close together and ungrouping makes it a challenge to regroup. Doing personnalisations on them is a pain, I now do them in Corel and use the macro to export to LB. I’d rather just use LB however.
You could try to use the variable text function in LightBurn as a workaround, depending on your specific use case. I don’t know if, for example, changing names / text in a CSV file is more convenient in your case…
