Is there a way in lightburn to send multiply files at once to a ruida controller.
now I have to open a file (complex files takes time) send it to the controller. (takes time, asks for file name)
etc etc for the other files.
would be nice when I can select multipy .lbrn files and select a controller en press send…
Those files are stored in the controller’s flash memory with that name, so you can re-run them at any time by selecting that file name on the machine’s display: there is no need to send them again.
The controller doesn’t provide a “multiple selection” interface to its filesystem, so you can run only a single job.
It’s worth noting that Ruida controllers develop weird problems when the flash filesystem fills up, so if you’ve been sending many different files for a long time, you should delete the ones you no longer need:
