Where is settings to set minimum distance (diode laser) that laser know to draw two paralel lines?
… do you mean the offset function?, try to explain yourself a little more precisely.
I downloaded a project where there were two parallel cutting lines at a distance of 0.30 mm and the other two were at a distance of 0.23 mm. In the first case the laser made two lines and in the second it did not make a cut. I remember reading somewhere that there is a setting that determines the minimum distance when the laser takes two lines as one or two.
The distance between 2 lines in LightBurn is only limited by your laser’s spot size. When you fill an area you can determine the line distance in mm. My laser for example has a spot size of approx. 0.1mm, which means that with a line distance of 0.9 I have a theoretical overlap of the line and thus get a continuous fill without gaps.
Is that what you mean?
In Optimization Settings there is a remove overlapping lines checkbox where you adjust the distance setting.
Thank you ![]()
