Setting gives problems
Hello,
I have just been actief white my cnc vevor S4040 router.
I have a work made and nou i want to carve this.
my router gos nuts on me he gets to the bottum and thats it.
what do i do wrong in my settings please help
The spindle travels past the set zero point; it goes right through the wood.
Without having your .mage file and not knowing what machine you are using, it is useless to offer suggestions to fix your issue.
Hi Jan,
How did you go about setting the workpiece zero? Did you manually jog the tool to the top of your job material and then set β€˜Z0’? Or did you zero (or use the z-probe) at the top of the spoil sheet (bottom of the material).
If you zeroed to the bottom of your material - but had your project Zero Point set to the β€˜Top’ of the material, the job will cut down too deep and through your material.
