Setting home position
just fitted a ruida 6432g controller kit in my k40.
i cant get it to home after cutting or engraving it will do it in rdworks but not in Lightburn.
i have limit switches in x and y set and working if i home from Lightburn it goes to top left.
I assume the K40 homes on power up to some other corner?
Are you using LmtX- or LmtX+ for limit inputs? And is it active high or low on your switches?
How did you set up Edit → Device Settings and ensure it’s configured, especially which corner it’s supposed to home.
did that all switches working as it should homes when pressing home in lightburn and rdworks and rdworks homes after cut etc.
after a few hours found a setting in rdworks on the right user then auxilliary and auto home is not on switched on and that solved that.
