I’ve read through manuals but it’s not coming together for me.
Controller = RuiDa ACS RDC644XG
I would like the job origin to be where I have placed the laser. But no matter where the head is when I press Origin, the upper left of my LB space corresponds to the upper left of the table (physical 0,0), rather than where the head was when I pressed Origin. I have gone into Z/U, Origin set, and cleared Multi Origin enable as the controller manual seems to say to do. However, no change, the origin still remains at physical 0,0. I’m wondering if I need to do something in LB as well to set where in the drawing area my job origin should be. Other systems I have used automatically set that to be at the upper left of drawing extents. In any case, a recipe for the job to start where I physically chose the job origin would be awesome. Thank you.
(I wrote and posted already but it didn’t take and I don’t see it so apologies if this is a duplicate)
I would like the job origin (upper left of drawing extents) to be where I set the laser head. However, pressing Origin on the machine does not set the origin there, even if, as the Ruida manual seems to say, I go into Z/U, Origin set+, and clear Multi Origin enable. I do not know what the four other Origin enables are for. It may be there’s something I need to set in LB as well, but my reading of the manuals does not reveal it to me. (I’ve no problem with moving my drawing so it’s all the way in the upper left corner (0,0) if that is necessary, but I still need the machine to start working where I tell it to.) Any help determining the recipe would be appreciated. Thank you.
Correct. It’s a quirk of the Ruida controllers. Go Scale or Frame will go from current position, but start goes from the Origin. I’m told it’s so you can move the head out of the way to set the next piece in place and keep your starting point. It would be nice if that was included in the Ruida documentation, but then again the Chinese to English leaves a lot to be desired any way.
FYI, for Ruida specific questions, they have an excellent user forum. https://rdworkslab.com/
Not in LightBurn - we actually correct for that. If you use the Frame buttons in LightBurn it will always frame at the correct location, regardless of where the laser head is currently placed. I don’t have control over the frame run from the controller panel itself though.
I do not have such a requirement with my Ruida 6445 controller (needing to use the origin button on the HMI). Wherever I place the head, start from current position starts the job right there. Framing is the same.
To clarify, anywhere my laser head is positioned is where the job will start from and is where the framing will start from when I have Current Position set for Start From.
Running the job:
Job Always Starts Where Head is at Rest; Origin is Set (reset) to the Current Position
Confirm this by:
pressing the Origin key on the HMI (this step here for proof only of the origin resetting by starting the job)
moving the head somewhere else
Start the job (the job will start from where the head lies)
When the job is over, double pressing ESC on the HMI, the head doesn’t move back to origin because it is already there where running the job established it
Framing the job:
Framing Always Starts Where Head is at Rest; Origin Unchanged (i.e., the framing origin is again anywhere I have the laser head, disregarding any origin of the machine. The framing, however, doesn’t reset the origin like running the job does).
Confirm this by:
framing the job (the framing will be from where the head lies)
pressing ESC twice on the HMI (the head will move back to where I had set the origin via the HMI)
