Where do I find setting to turn of laser at home position
Welcome John.
The laser should be off:
Did you create your device in Lightburn?
Did you update your laser firmware?
Expand a bit further.
Firmare is up to date
Manually imported laser configuration from Creality
Laser does engraving OK and laser beam shuts off device returns to home but keeps running
Did your laser come with a markcfg7.cfg file?
Does the laser “signal” the home position?
Or do you have some bad home switch or broken switch wire?
Type ? and press Enter in console window then while pressing the home switches type ? again and copy/paste here the output of the two lines.
No I don’t have that file
Tried typing? & that’s all I got
When I use the Creality program the laser goes home & beam stops after a few minutes
any other suggestions for me?
Finally figured out what you are asking…see attached[1]
[0;31mE (297803) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m [0;31mE (297805) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m [0;31mE (298458) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m [0;31mE (298459) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m [0;31mE (298461) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m [0;31mE (298462) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m ok ok [0;31mE (302250) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m [0;31mE (302252) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m [0;31mE (302899) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m [0;31mE (302900) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m [0;31mE (302902) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m [0;31mE (302903) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first[0m ok ok
Footnotes ↩︎
Update, problem resolved after last softeare update all is good
Are you saying a software update solved the problem? Was it Lightburn or the controller software?
it was the Lightburn update
