I am having trouble setting up the camera alignment. When I go to burn / cut the program, my machine traces it out and runs, but does not cut. Thoughts?
“Does not cut” meaning the beam is off and you’re getting no output? What settings did you use?
Correct. If I engrave or cut, I have to send the image from lightburn to the machine, then pull no the file on the machine and run it. I have never been able to simply run a design straight from the software. So…when I go to run the alignment, all the laser does is go back and forth where the image is but does not burn. (It is not loaded in the machine itself) I hope this is making sense
This would’ve been good to mention from the start, as it does not sound like the issue has anything at all to do with the camera. How are you connected to the machine?
