Setting up library
I just purchased online and downloaded almost 4,500 svg files. Is there a simple way to add them to my library for quick and easy use?
In Art Library window there’s an “Import” button. Push that, you can then choose multiple files to import. I’m not sure if there’s a practical limit to how many can be selected.
I’ll caution that even if something is packaged as an SVG that it may not really be in laser ready form. Even purchased SVGs may be of low quality or malformed in some ways. If this matters to you then you may want to curate or clean up the designs before adding them to your library.
If you cleanup within LightBurn you can use “Import Graphic from Project” to add to your library. I believe this has to be done one set of shapes at a time, basically whatever is selected at the time.
