Tried to set up my Laser Master 3 in Light Burn. Machine went into alarm and I couldn’t find how to clear alarm thru Light Burn’s console.
Makes sense except for my screen doesn’t show devices button. on the left it shows the design grid. On the right, at the top it shows the movement console. At the bottom right it has a window, Console-Lightburn 1.3.01, 2ith some Homing dialogue followed by 6 Macro buttons 0 thru 5. As it stands right now, I’ve got a paid investment that will not talk to a 500 dollar paper weight. Really frustrating at this point. Oh, the only thing it will do in Lightburn is home when the app is opened.
Select Window, Select Laser check box is enabled then in the Laser window you can right click Devices.
ok, got them communicating now. Next issue is half of my design screen, the right, is gridded starting at 0 and increasing. The left half is blank starting at 0 decreasing. Any text starts at zero and as it is typed it backs up into negative numbers. I had the demo version of lightburn on this laptop and bought the key. Didn’t have this issue in Demo mode.
I’ll look this over in a bit. One thing at a time. Thanks for the help.
I’ll apoligize in advance for all the questions. You probably thinking what’s up with this guy, but here I am again. I can’t seem to find the jog station. All I have right now is the start/pause/stop/frame block. I know it’s there I just don’t know where to look.
No problem! Go to the top bar menu and select ‘Window > Move’ and the new tab will appear on the top right panel of the LightBurn window.
Thank You for your help
