How do i set work space from Metrik to inch.
The simplest way:
I don’t see that option in my version. But, you can click the cogs for settings and make the change there. Oh, and I tried using inches in another laser program. Found that it is easier to use MM.
You’re likely a couple versions behind - 0.9.07 is the current release, and that feature has been in since 0.9.05.
Yep, you are right. I was using 0.9.04. Upgrading now. Thanks
