# Settings Atomstack A5 Pro doesn't work
**URL:** <https://forum.lightburnsoftware.com/t/settings-atomstack-a5-pro-doesnt-work/72061>\
**Created:** [July 22, 2022, 11:03pm UTC](https://forum.lightburnsoftware.com/t/settings-atomstack-a5-pro-doesnt-work/72061 "2022-07-22T23:03:20Z")\
**Showing post:** 37
**Author:** ![flux\_capacitor](https://forum.lightburnsoftware.com/user_avatar/forum.lightburnsoftware.com/flux_capacitor/32/47849_2.png) [@flux\_capacitor](https://forum.lightburnsoftware.com/u/flux_capacitor)\
**Post date:** [September 4, 2022, 11:43pm UTC](https://forum.lightburnsoftware.com/t/settings-atomstack-a5-pro-doesnt-work/72061/37 "2022-09-04T23:43:12Z")
I confirm that my A5 Pro+ is not automatically detected by Lightburn using the button “Find My Laser”, but works using “Create Manually”. This is weird I concur. I have a MacBook Air M1 with macOS Monterey 12.5, and I connect the Atomstack to the Mac using the USB-A to USB-B cable provided in the box and an Apple USB-C to USB adapter.
I will try again a direct connection without adapter when I buy a USB-B to USB-C cable. But it seems that such cables only exist unshielded, with no ferrite. Another oddity.
EDIT: It seems there is really an issue with this machine and current macOS, see the various posts on the same subject:
> [@Atomstack on Mac Monterey](https://forum.lightburnsoftware.com/t/atomstack-on-mac-monterey/65324/2):
> The USB Serial device listed looks like it could be the laser. Do you have any other devices connected that could be using the CH340 driver? Do you see the laser listed in the ports list: ls /dev/tty.wchusbserial\* If you haven’t already tried, disconnect all other devices other then follow this sequence: turn on the laser open lightburn Use Find My Laser or create manually. It’s possible that it won’t get auto-detected.
> [@Lightburn not finding AtomStack A5 Pro+](https://forum.lightburnsoftware.com/t/lightburn-not-finding-atomstack-a5-pro/67217/3):
> Connect your Atomstack to the Mac with the USB cable and power everything up. The CH340 driver is first. Once that’s there you’ll have to manually create the device. Open the Laser Window (If it’s not yet open go to the top row of LightBurn and hit Window and make sure Laser has a check mark beside it - if it does it’s active and probably docked. In the Laser window, click Devices (bottom Left), when the next window pops up click ‘Create manually’. Select GRBL make up any other information…
> [@Unable to "find my laser" - Atomstack A5 Pro - macOS 12/macOS 10.13](https://forum.lightburnsoftware.com/t/unable-to-find-my-laser-atomstack-a5-pro-macos-12-macos-10-13/68778):
> The “find my laser” feature does not seem to be able to find my Atomstack A5 Pro. I started with using an M1 Macbook Air running latest stable macOS 12.4. I installed the CH340 drivers (which I assume to be correct from googling. The official atomstack page for driver downloads for the a5 is no longer found), but received an error that the drivers are built for x86/x64 arch. I then moved to an Intel Macbook Pro running nearly-latest stable macOS 12.3.1. I installed the CH340 drivers, but am re…
I give only three, there are others.
Atomstack says this machine is compatible with macOS when using Lightburn. It’s in the web site and the manual that comes with the machine.
All solutions provided in the Lightburn forum consist of asking to configure the machine manually.
_[View the full topic](https://forum.lightburnsoftware.com/t/settings-atomstack-a5-pro-doesnt-work/72061)._
