I have been using this version for a while but regret the latest updates.
I would love to be able to go back a few versions…
Several things have changed and I cannot seem to get them working as before
- Not remembering layer order :
Eg : I need to cut/engrave some pieces out of similar material, but use different AI exports.
File 1 is set one for a building kit, File 2 is set number to for the same kit and so on.
In former versions, when setting the order of the colors to follow one time, I could import any new
file, the order stayed the same. Now every time I import a file, the layer/color order changes randomly. Very time consuming.
- Inner to outer changed somehow :
Al my designs, for more then 10 years now, are made so the material between to pieces to
cut are cut in smaller pieces, so they can drop easily down in my machine. If not they tend to flip sometimes, coming in the way of the laserhead. The laserhead then hits these and moves the
material… lost set because everything is shifted some mm’s by the hit.
This was fine in former versions, the new version does not cut inner to outher in the same order
anymore. See picture here enclosed.
