Hi ive recently upgraded from the k40 to a bigger machine sh-g570 which I’ve upgraded to the dsp software
it seems the laser is crashing into the side and doesn’t stop I’ve looking in various sections of the lightburn software but im not sure if anything need altering
I’ve tried different things all day i cant even factory reset the board as its pass worded
It sounds like you limit switch may not be. functioning properly. When you power on the machine, does the head go to a corner, stop then move a small distance way?
No it just smashes in to the side and doesn’t stop unless I press the stop button it was OK earlier I did alter the polarity of the x,y axis and the trouble started
I’ve taken a picture of the board it seems the all the axis are on 100000
That’s the problem, why did you alter the polarity? That will change the direction of travel.
Before you touch anything in the controller, make a backup of the settings. You are fortunate that you didn’t reset the controller. These are generic controllers, each manufacturer sets them up specifically for the machine, including the number of steps/rotation and MANY other things that you would have to guess at and probably end up going back to your manufacturer before it would ever run properly again.
Back it up!
Are you trying to get it to ‘home’ somewhere other than where it was setup to home?
This is by design, as many laser systems pull the exhaust to the back of the machine. The design is to not draw the smoke back across your finished work. You can flip the fill the ‘Scan Angle’ to 180º to have the job process as you’d like.
Hi
It was when I read on one of the lightburn topics of changing polarity of the axis since then it went wrong only I didn’t make a backup of the old script
I was wondering if anyone could send me their file of settings and I’ll load it into mine
hi
it hits the frame when starting up for some reason the home went from top right now to top left
i haven’t managed to cut anything as yet
the axis are all x,y,u are all 10000,0
when i click home with in LB it crashes into the left hand top on setup i set it to top right
I cannot remember if I changed it don’t think I did was just the polarity of the x,y axis is there anything within the control board I could of altered without knowing ?
In the para settings on machine config
