Hi! I have a 60w laser, started using LB last week, I can cut perfectly but the engraving looks completely shaky (I tried this file before on other lasers and it worked great, didn’t look like this at all). Any clues of what might be causing this? Also happens with text etc created directly on LB. Thank you!
Not without a bit more information and maybe a cleaner image showing the issue. The one here is not very clear and fairly low-resolution, difficult to see. Share the settings used for this. Help us to “see” what you are observing and how this should look, and we can go from there.
