Shape levelling in lightburn
Im having trouble getting shapes to snap level. At the moment, im using rotate on the selected shape, but some large shapes i cannot zoom close enough to see the shape line and grid to get it accurate.
Searching for a solution online have come up with nothing, and i cant see anything that would work in lightburn. i hope this makes sense and if someone can help. Or does lightburn not have this feature?
If I’m understanding you correctly you may be able to use the “Align selected” feature of Node Edits tool. Hover over the line segment that you want aligned while in Node Edits tool and then push A key.
Not at computer with LB on it, but wondering if this might work, draw a line where it will show when zoomed in, lock into position and make it a toolpath, then align to that ?
