Shaped text is losing shape after ungrouping
We do lots of text that is shaped to a curve. Since installing 2.1.00, anytime this text is part of a group, when it is ungrouped, it straightens the text into a line instead of its original arc.
I tried to see if I could find this issue recorded already, but didn’t see anything. Is there a workaround? Or do I need to roll back to a previous version?
When you say “shaped” do you mean “apply path to text”?
Do you have a simple example I can look at? We’re going to have a patch release very soon, so it’s possible this could be fixed before that release.
Probably shaped was the wrong word to use. :slight_smile: I meant text that has been curved using the purple dot in the first image. This image is before grouping.
The second image is after grouping, then ungrouping.
Ahh, ok - That’s likely simpler to find. Thanks for the response - I’ll look into that now.
Did you start with a very large design and then scale it down a lot, by chance? I think I see what’s happening.
This will be fixed in the 2.1.02 patch.
If that did happen it was long ago in this designs history. This is a basic template we copy and paste. Regardless, thanks for jumping on this right away!
The patch with the included fix will likely be released on Monday.
I just now got this downloaded and tested. Sadly this is still happening…
Can you email the file that you’re having the issue with? Without it, I’m largely guessing.
Email it to support@lightburnsoftware.com and include a link to this thread.
Email is sent..
This is fixed and will be in the next patch.
