Good evening everyone,
I uninstalled light burn from the laptop and installed it on a stationary computer.
Τhe problem is that when I go to press shift and frame to show the laser light it doesn’t show it while on the laptop it does normally.
The shift on the keyboard works normally, I can’t figure out what’s wrong.
Also, when I installed again, the program did not mention the name of leizer as in the first installation, it sees it but does not write falcon 2 as when I first installed it.
Please help me!!!
Thanks in advance
Go to Edit->Device Settings and make sure that “Enable Laser Fire Button” is enabled. In Move window, set the power level to the proper level for your laser for framing. If you want to enable laser for all framing operation then also enable “Laser on when framing” at the proper power level.
Oh thank you so much…everything is fine now!!!
That does not transfer the settings from one machine to another.
To get that done:
