Good afternoon,
I’ve been using Lightburn for a couple of years and it’s my favorite software.
This week I updated to version 1.7.01 and there are a couple of tasks I can’t do.
Ctrl+c or ctrl+v doesn’t work for me to copy and paste. Also I can’t join lines with Alt+J either.
Since I have updated from version 1.3, I don’t know if the way to do it was changed at some point.
This is because our translators broke the shortcuts in Spanish. We have an update coming shortly to correct this. If you use the software in English, the shortcuts will work until we get the patch fix done.
I have changed the language from lightburn to English and it doesn’t work. I have also changed the keyboard language in the Windows options and it still doesn’t work.
In case it helps you solve it.
Can you go to File > Preferences > Edit Hotkeys
Then click on the “Edit Menu” entry on the left and check what your shortcuts are for Copy and Paste?
As @LightBurn note we had an issue with the translations but this was fixed in v1.7.01
I just confirmed again locally that it works as expected in Spanish and English. The fact that it’s still broken in English for you leads me to believe that you simply have a bad shortcut saved. Possible it got there from the broken shortcuts in v1.7.00
You could also try clicking the “Reset All” button at the bottom left which will likely just solve the problem.
Perfect! After resetting the keyboard shortcuts to default values everything works again. Thanks a lot for the help
