Since 1.1.03 upgrade, fill won't fill
Since upgrading to 1.1.03, when I choose fill mode, the item doesn’t fill. I went back to 1.1.02 and now it doesn’t either. I opened files I know had fill set in them, they also are showing only as lines. Why? :exploding_head:
if you are saying that the objects are not showing as ‘filled’ in the workspace then you may not have selected one of the 2 ‘filled’ options found within the ‘Window’ dropdown menu
Duuuude, give me some credit, of course I have fill chosen. I get the same result with fill+line.
That wasn’t my suggestion, I asked if you have either 'filled/course or filled/smooth selected in the ‘Window’ drop down menu
I sincerely apologize, I do now! thank you!
No problem, glad it’s sorted
