Dear all,
When I engrave a text, the “line” option engraves the outline of each letter.
I’d like to find a way to engrave only the path of each letter as a single line.
In advance, thank for your help !
Dear all,
If I understand correctly, what you want isn’t what you’re thinking.
You want the laser to draw the letter in a single line when engraving.
The only way to achieve this would be to reduce the line width to the dimension of the laser beam at the focal point.
I believe it’s a diode laser machine, so the focal point should be around 0.08mm more or less. A line of that thickness is practically imperceptible. For this reason, it’s necessary to use “Fill” instead of “Line” in order to fill the empty space between the lines that draw the letter, thus creating a single line.
An image of what happens and what you want would help to better understand if what I mentioned is correct or not.
Try a Google search for SHX fonts.
SHX is different from TT fonts. They are AutoCAD text fonts. They are not recognized by Windows, but will show up in the font list of Lightburn. You install them on a Lightburn folder and tell Lightburn where they are located. The whole process is quite easy.
I burned readable text 1mm(!) tall on Baltic Birch with a 10w diode laser.
LightBurn docs have it:
Well, that’s a different matter altogether. Suggestions have already been made for that. ![]()
Hello Mikey,
Thank you for your answer. Could you please explain how to tell Lightburn where those fonts are located.
Forgot to mention it was the ISO9 font for the tiny text.
