Skipping a basic line
ortur LM II
When engraving a basic square or rectangle on a flat or any surface is skipping.
in preview it show the shape no problem. When actually burning the shape, the laser will miss/shut off in random spots
Then there is a mechanical or electrical problem.
Start by checking all the connectors and wiring from the laser head to the control board, looking for anything loose or frayed.
A connector pin inside its plastic shell can work loose from the wire it’s supposed to be crimped on, which is hard to find unless you pull gently on each wire; the bad crimp will pop right off.
Thanks for the review. i checked the connections I changed the layer, and it worked fine.
Strange…
thanks for the advice on checking my connections. ill be back for more questions soon, im sure.
