I was trying to resize all slots in the attached file from 4mm to 3mm, but only some resized. Any idea why? I checked the sections were all 4mm, and they are - so not sure what’s causing it.
triangle box.lbrn2 (26.1 KB)
The slots that are not recognised for resizing have extra nodes coincident with another node. Here’s one of the slots selected which should have 4 nodes but has 5:
You can either delete these manually or use the “Optimize Shapes” tool.
EDIT:
Once you’ve removed the extra nodes you can successfully resize the slots.
ah - so I couldn’t see it because it was an overlapping node?
Correct.
I looked for differences in the slots and I didn’t see anything. I went as far as to break them apart and rejoin them and still not working.
I didn’t think about the Optomize shapes tool, genius. The extra nodes are hidden behind the start node and even at fulll zoom are not visible.
I actually spotted the extra node when I tried dragging a corner node.
