When using rotary attachment the laser moves very fast to the start point of the job, I’m concerned it moves to fast that the cup my slip a little… how do I slow down the laser head from the start point( center) to its initial engraving point (lower left)
For a Ruida, go to Edit > Machine Settings and change:
- Idle Speed
- Line Shift Speed
You should record the original values, as you’ll likely want to restore them when you’re finished.
You could also override both easily by changing the Y Axis Settings maximum speed to a lower value, as that number takes precedence.
