Slow engraving with snapmaker
Hi there
im fairly new to laser engraving and got the snapmaker a350 as i did not know what i would enjoy more 3d printing or laser engraving.
so i have a 10w laser that can feed at 6000mmpm however i go to do some engravings and it is clearly not this fast it seems to stop and start on each moment. to engrave a 100mmx100mm coaster it takes around 6 hours i have seen other peoples work travailing at a slower speed complete a job of the same size and detail in 1 1/2 hours.
i have looked over the internet for a solution and got part of one, in light burn i edit my snapmaker and use the Marlin control. and then i got to device settings and turn on laser control Inline.
i then send a job to the machine and run it the feed is great- faster then i have ever seen the machine go but the laser itself will not fire so i done engrave anything.
i am hoping bigger brains then mine know how to help
below is part of code for snampaker that takes around 6 hours below that is the inline code
snapmaker code
;Header Start
;header_type: laser
;file_total_lines:1256548
;max_x(mm): 212.04
;max_y(mm): 224.83
;max_z(mm): 0
;min_x(mm): 107.88
;min_y(mm): 125.09
;min_z(mm): 0
;Header End
; LightBurn 1.3.01
; SnapMaker device profile, user origin
; Bounds: X107.88 Y125.09 to X212.04 Y224.83
G21
G90
G0 X0 Y0 F0
G91
; Image @ 4999.998 mm/min, 10% power
M106 P0 S255
M05
G0 X-51.444 Y-49.911 F0
; Layer C00
G1 X2.083 F5000
M03 P10 S25.5
G1 X0.085
M05
G1 X0.593
M03 P10 S25.5
G1 X0.084
inline code
; LightBurn 1.3.01
; Marlin device profile, user origin
; Bounds: X108.71 Y125.09 to X211.2 Y224.83
G21
G90
G0 X0 Y0 F0
G91
; Image @ 3000 mm/min, 10% power
M8
M05
G0 X-50.611 Y-49.911 F0
; Layer C00
G1 X1.25 F3000 I S0
G1 X0.085 I S25.5
G1 X0.593 I S0
G1 X0.084 I S25.5
G1 X1.27 I S0
G1 X0.085 I S25.5
G1 X0.169 I S0
G1 X0.085 I S25.5
G1 X0.762 I S0
G1 X0.085 I S25.5
G1 X0.084 I S0
G1 X0.085 I S25.5
G1 X0.085 I S0
G1 X0.084 I S25.5
G1 X0.085 I S0
many thanks for any help. i have also sent a request direct to snapmaker. any information i will relay on here.
Graham
