When I move at below 10mms the laser does not switch of when moving from one cut path to the next. Which makes a travel line on the wood piece.
Is there a setting to enable this.
Above 10mm it does switch of when moving to the next move.
M3 will work, but you should double check the S-Value Max setting in LightBurn matches the $30 setting in the controller. M4 is better for vector marking as it ramps the power with velocity changes and gives a more consistent burn.
