Small camera image area after calibration
GWEIKE CLOUD LASER
LB Version 2.1.03
I am trying to setup my camera. During the lens calibration the camera shows the complete cutting area (approx. 20 x 11.5). I completed the lens calibration successfully.
I then try to complete the workspace alignment part. The trouble is during this portion of the setup the camera image displays is only a small portion of the the cutting surface (approx. 14 x 9) area.
When I burn the alignment symbols for the full size of the cutting area they are outside the image area.
So I burned the symbols into the smaller area. I was able to complete the workspace alignment but the usable area is much smaller then the actual cutting area.
My question is why is the image area for the camera calibration so much larger than the camera image area for the alignment calibration?
Is there anything I can do to perform the workspace alignment against the entire cutting area instead to just the smaller portion. Make the camera image is basically the same size as the cutting area.
Right now there is about 100 mm of on both edges I can’t see with the camera which is a little annoying.
Please show us what you see.
A screenshot of the entire LightBurn window showing the camera preview and the Overlay.
I missed the icon to upload images, but I see it here.
I uploaded 4 images one is the camera alignment, one is from the workspace alignment, one is a photo of the laser bed with 4 disk spread from one edge to another and finally what it actually looks like as an overlay in Lightburn. There are four disk, but the overlay only shows the middle two. I see there are adjustments, but it just zooms the overlay and does not actually expands the image. I hope this helps…
In picture 1 it is clearly seen that the lens calibration is not as it should be.
Your working area from your laser should be displayed in both windows without distortion and without missing any space from your machine bed.
ps. a correction of 25 mm in X shift is also completely unacceptable and indicates an error, in my opinion
The 25% setting was me just playing around with those setting to see what they did. All they do is manipulate the existing image, I can make the inherently small image to cover the entire laser bed for example], which does not solve the underlying problem. They have no impact on expanding the actual image.
“Adjust Overlay” is intended for fine-tuning the workspace after a successful calibration of the camera lens and should be in the sub mm range.
As said before, you should start over with lens calibration and see if that gives you an image with straight lines and edges, then you can adjust/align your workspace.
Is there any information on what not to do during the calibration? That is one place where I felt I was doing a walkabout.
Not accepting bad results
Not having a guaranteed static camera mount in the middle of your workspace.
An “inappropriate” camera (too large or small field of view)
Not moving the target plate during workspace alignment
Choosing the wrong camera profile after lens calibration
:rofl: I meant during the calibration steps! I was unsure of the procedure steps, like could I rotate the April Tags or not.
Also, can I go back and lens recalibrate without having to redo the rest of the setup procedure?
…Just learned, nope.
The orientation of the April Target doesn’t matter, I actually rotate my board/target plate all the time to get variance, if that helps? - I don’t know :wink:
After each lens calibration I do a workspace alignment with my alignment plate, which I reuse. But as I said, this can only be done if you can place the plate 100% repeatably!!! The process takes less than 1 minute, enter, enter, enter, enter… :wink:
I updated my original posting. I hope some find it useful. I know “First Try” is a bit misleading, but it is what it is! :rofl:
