Hello, I have an algolaser diy kit mk2 printer. I recently bought a smart camera to make it easier to make cuts after certain pictures and I can’t calibrate the camera so that it is in the same position as the outline. When I give it FRAME, the laser moves 1-2 cm further from the drawing on the sheet. I did 7 calibrations according to the video and the same problem appears. Can you help me with some advice on how to calibrate it better so that the laser cuts where I put the outline of the drawing? It’s possible that I’m missing something and not realizing some essential settings.
Welcome @soareflorin try adjusting X and Y Shift, please read Lightburn official doc:
What is a smart camera? For the camera function of LB, it’s best to have a dumb camera; even autofocus is already bad. You can use a simple webcam as well.
Does the laser have a red dot pointer? Is it turned on or off?
