Smoothie Clustering
In den alten Versionen von Lightburn ist die Funktion smoothie clustering ersichtlich. leider in den neueren (1.3.01) nicht mehr. Es ist nur gcode clustering vorhanden, dies macht aber Probleme mit meinem Omtech K40. Es bricht immer wieder den Auftrag ab.
gibt es diese Funktion nun versteckt oder muss ich wo anders etwas einstellen?
Vielen Dank
In the old versions of Lightburn, the function smoothie clustering can be seen. unfortunately in the newer (1.3.01) no longer. Only gcode clustering is available, but this causes problems with my Omtech K40. It keeps aborting the order.
Is this function hidden or do I have to set something else somewhere else?
Thanks very much
LB0.9.24
I was under the impression that the implementations were the same for both. Are you certain the issue you’re experiencing is caused by g-code clustering?
Hy, i have my omtech sinsce 4 weeks and omtech description and support means smoothie clustering must be on but if i turn gcode clustering on i get connection problems. If i turn of i have no connection problem but i can not engrave pictures with the speed i want (100mm/sec without breaking times).
I will test a older version of lightburn with the smoothie clustering function.
When you do this can you save the gcode for both the latest version and the older version to compare?
Smoothieware clustering was simply renamed to GCode clustering because it is now supported by a number of non-Smoothieware systems as well. The functionality has not changed.
