Smoothieware device shows CNC‑style controls — no laser options
Hi all,
I’m running an Omtech K40+ with a Cohesion3D Mini (Smoothieware), and LightBurn is treating the machine like a CNC router instead of a laser. I’m missing several laser‑specific options that normally appear for Smoothieware devices.
Symptoms:
  • No “Laser Mode” or laser‑specific device settings in LightBurn
  • No S‑value / power controls
  • No PWM options (expected, but the UI still looks CNC‑oriented)
  • G‑code output looks like CNC spindle commands rather than laser commands, no M3
  • The laser does not fire at all from LightBurn or from M3/M5 commands
  • Homing works correctly now, but the laser behaviour never changed
What I’ve already checked:
  • Device is added as “Smoothieware” (not GRBL, not Marlin)
  • Using ON/OFF mode in Smoothieware (laser_module_enable false and switch.laserfire block)
  • M3/M5 commands are accepted by the controller, but the laser never fires
The core issue:
Even with the correct Smoothieware config for ON/OFF laser control, LightBurn still presents a CNC‑style interface and the laser never fires. It feels like LightBurn is not recognising the controller as a laser device at all.
My question:
Is there something in Smoothieware, the device profile, or LightBurn’s detection logic that would cause LightBurn to hide laser options and fall back to CNC behaviour? What should I check to make LightBurn recognise this as a laser controller and allow proper M3/M5 firing?
Any insight from people familiar with Smoothieware + LightBurn would be appreciated.
Thanks,
Brian
Smoothieware controllers do not expose the motion or laser settings over the USB connection.
The settings are only available in the config file onboard the device.
To adjust the settings, one must edit the config file.
Regardless of the hardware type, LightBurn is designed to remove, grey-out or blank out any settings that are not available for a given hardware profile.
I worked with someone and got a Smoothie controlled K40 type machine going here a couple of years ago. It was a fight. I’ll see if I can chase the thread down.
Edit: Found it
Thanks John, that’s really helpful context - makes sense that it’s all config-file driven rather than anything LightBurn can toggle, which matches how I’ve been working with it (editing config.txt directly on the SD card).
If you can track down that old thread, I’d really appreciate it - I’ve got a fairly detailed technical history built up on my main thread here if it’s useful for comparison against whatever you got working before:
Short version: motion (X/Y, endstops, homing) all works fine through LightBurn. The laser itself won’t fire - I’ve confirmed the PSU’s L (fire enable) and IN (power level) terminals are the right ones to use, and L toggles correctly via M3/M5, but I haven’t yet gotten real current to flow even with both L and IN driven together. Getting good input from a couple of others on that thread too working through PSU-side wiring specifics.
Would be great to see how a working Smoothie K40 setup was wired if you can find it.
Thanks,
Brian
