Hi, I’m relatively new to Lightburn/Lasers. For some reason my snap to objects is not working (snap to grid is). I tried searching here and the net but couldn’t find a discussion thread anywhere.
TIA - Craig
TIA - Craig
Please explain this in a bit more detail. What do you have set for snapping in the Settings window?
These are worth review and should be helpful, Redirecting...
Yeah even my cursor does not change to crosshairs like that when I move to a corner.
can you show us with a little video?
Your ‘Object snap distance’ is only 0.1 pixel, mine is 10. I don’t know if that could cause the issue, but may be worth upping it and see if it works.
Thanks to your comment I now know how to do a video screen grab! Thanks! All solved though now, so no need
Thanks, this was it! My crosshairs are there and it snaps now! Thank you!
glad to know that all works well
This had me thinking, so tested with set to the same. While it is a bit more difficult to do with these settings, it does still change the cursor shape and snap to other snap points as expected.
Maybe it just jarred something loose in the program for me…
