# Snapmaker Ray - no crosshairs when framing
**URL:** <https://forum.lightburnsoftware.com/t/snapmaker-ray-no-crosshairs-when-framing/130496>\
**Tags:** snapmaker, snapmaker-ray, ver:v1-6-8-20240124\
**Created:** [February 20, 2024, 8:52pm UTC](https://forum.lightburnsoftware.com/t/snapmaker-ray-no-crosshairs-when-framing/130496 "2024-02-20T20:52:22Z")\
**Showing post:** 32
**Author:** ![berainlb](https://forum.lightburnsoftware.com/letter_avatar_proxy/v4/letter/b/85f322/32.png) [@berainlb](https://forum.lightburnsoftware.com/u/berainlb)\
**Post date:** [February 24, 2024, 8:28am UTC](https://forum.lightburnsoftware.com/t/snapmaker-ray-no-crosshairs-when-framing/130496/32 "2024-02-24T08:28:33Z")
I’m looking back at a separate topic with a Snapmaker Ray. I’m not sure what’s going on but it seems like these machines are not getting shipped with the proper configuration or it’s not clear how they’re meant to work.
The conclusion in that Topic was that machine homed top-left with origin at bottom-left. In order to accommodate this a work offset was applied.
> [@Everything is inverted](https://forum.lightburnsoftware.com/t/everything-is-inverted/127646):
> please help. brand new Snapmaker ray out of the box. updated to latest firmware. homes correctly to top left. but when I start to cut its all inverted. I have changed the origin and just makes things worse. the x axis is running as normal but the y axis is running inviter into the negatives. I have edited the machine setting to invert and got the x and y running in the correct orientation but hit start and the laser shoots to the other side and smacks into the wall. I have gone over every si…
Let’s reproduce that.
Can you run these commands in Console:
```auto
G10 L2 P1 X0Y-400
$10=0
Then home the machine. Test jogging controls to make sure they work correctly. Then run a job to make sure that things are oriented correctly.
Test the laser positioning to make sure that’s working correctly.
_[View the full topic](https://forum.lightburnsoftware.com/t/snapmaker-ray-no-crosshairs-when-framing/130496)._
