So I am attempting to make the areas I marked cut out, this is a overlay piece and I had to weld the stitching to the plate so I’m not sure how to get it right
Just select the 3 “inner” vectors and cut them.
Don’t forget the 3 small pieces at the top.
If it is still a problem, upload the Lightburn design file and somebody can check it.
After I weld it can I ungroup the shapes in LightBurn?
Your graphic is drawn in a way that will cut those parts out leaving the plate and stitches attached. I don’t understand the problem.
Set your layer to line, set your speed and power to cut of your material.
Man you know you’re right haha I looked at the mock a did on a board and got in my head about it. I appreciate you
