I am having an issue where the original file I opened had all my objects oriented .15 and .15 from 0,0. Now when I open the file, I get this (see below). I had to readd my laser for some reason after the resent update.
In what way are you saying the position doesn’t reflect your selection? I can’t see the entirety of it but from what I can see the numbers look correct.
Note that you have the middle selected in the grid and inches for units:
Looks to me like the middle selection node that’s highlighted aligns between the 3.1 and 3.5 ruler marks which would put it right at 3.4216 inches as indicated.
Thank you. I apparently ignored that as I set my origin rear left after resetting everything up, again and missed that.
