For some reason Lightburn is changing the size of my project. Im trying to frame an item and I make sure the frame and item are the exact same size, go to cut and the frame is too small. Go to check the size and somehow lightburn changed the size. I tried making it the same size again, click off of the frame and then back onto the frame, and it changed to a whole different size (still not the same as the other item). What is wrong and why does it keep changing on its own? I lock in the size after I change it. Thanks!
Can you show pictures of what you mean, with the numbers changing? It’s not clear what’s happening from your description.
