Software problem i think
So ill do a design then before i start ill look at the preview it will tell me it will take about 48 min to complete but when i press start it actually takes my machine ± 3 hours to complete…
So now i just want to know …am i doing something wrong or do i have my settings wrong or is a normal thing ?
The simulation will copy the movements of the engraver, but not its speed. The preview time is usually inaccurate for this reason, but a difference of that caliber means it’s not set up properly. If you go to edit → device settings → additional settings you can configure the simulation’s speed settings. Clicking read from controller should give more accurate results.
Trying to get it 100% accurate is a fool’s errand as there are some aspects it wont account for.
After you “read from controller”, you can also edit those entries manually to further refine the calculations.
My machine uses a non-standard GRBL config and doesn’t properly report max speeds and accelerations to LB (not LB’s fault), so I had to adjust pretty much every entry by hand. It’s still not perfect, but it’s typically within a few percent.
Next to the “read from controller” thing, I’d like to add that the laser has physical limits and LightBurn doesn’t :slight_smile:
Even if the firmware allows to run at 50,000mm/min and the manufacturer tells you so, it doesn’t mean that the laser mechanics can move that fast. Another limitation is the serial data transmission. Stay below 10,000mm/min (better below 6000) and you should be closer to the real execution time.
