Solved Autofocus with L2 for ATOMSTACK PRO and SWIITOL PRO
Some people have problems activating the autofocus after installing the ATOMSTACK L2 autofocus Z-axis. It’s actually quite simple:
  1. After installing the L2, connect your machine to the Atomstack APP.
  2. In the machine configuration, you can activate “Autofocus” and “Fire Detection”.
  • I personally did not activate Fire Detection, because it triggers ALARM 12 even with minimal smoke.
  1. In LightBurn, enable the Z-Axis and set it to relative movement.
  2. In the machine settings, make sure $102 is set to 1600.000 (since 3200.000 moves the axis 2mm per mm).
That’s it!
Hope this helps someone.
