Some advice on picture engraving
Hello, I’m new to photo engraving and would really appreciate some advice.
I’m trying to engrave this photo of a horse, but I just can’t seem to get a good result yet.
I’ve already experimented with the contrast and brightness of the image, as well as different engraving speeds and power settings. My machine is a 60W CO₂ laser with a Ruida controller. I’ve also tried engraving both with and without air assist, but I still haven’t achieved the result I’m looking for.
Any tips or recommendations would be greatly appreciated. Thank you!
Hey Mitch I’m into it a couple years now. Still wet behind the ears. I’ve concluded this is a hobby art form. It’s difficult getting a printer to be as good as we would like. For me wood is no good for images except abstract and you want to burn against the grain. They say basswood is best. Take a black rattle can and coat a piece of aluminum and a piece of glass. Moderate speed, low power, 280DPI, Atkinson. A couple of yours look pretty good from here.
I’ve had some decent pictures on birch ply. Here are my settings on a 60w co2. Maybe they’ll help maybe they won’t lol.
Hello Mitch, welcome to the forum. :tada:
One of the issues with photographs is they cannot produce a direct gray range. Even if it’s a dither, the material has to handle the probable range.
I’d suggest you check out a video by Laser Everything entitled The COMPLETE Photo Engraving Guide Part 1 | Fiber CO2 UV and Diode.
Although done on a fiber machine, the process works for any material and any laser. Worth taking a look at. I think it’s one of the best.
Good luck.
:grinning_cat:
Mitch
Could you upload the file.
A good image is developing but needs a little work. Can you Drop the Dpi to about 230, Add a little Sharpening, switch to Stuki (Nothing wrong with Jarvis but…), Contrast +5, Brightness -5, Gamma 750+/-, Speed 3000, Power 18.5%.
Thnx, i will try this and show it here.
These are the results now.
Mitch
Well that’s no good, is it.
The photo you took has the best yet at the top right..if you’ll agree.
Can you post the settings for that image (Top right)
I see you have Max and Min power both set to 35%…So that means your in Greyscale (Your settings page appears different to mine), but your settings say Jarvis so hmm New Version.
I should have spotted that..Sorry. So your max power should be burning at the darkest without charring, And your min power should be Not burning at all…For the brightest patches like on the horses nose. (If you don’t want the brightest areas as bright as the wood itself, you can set the Min power to where it just leaves a mark, for me that’s 2.5%+ with 20w diode.
The span of power in between those two burns all other shades. But Jarvis is a Dither pattern so dot spacing takes care of various tones and shades.
Could you screenshot and post the cut settings window of the numbers I gave you.
And PS, what laser dot size is it?
PPS, Oh darn, that’s not your settings page as pictured above…Try to screenshot yours and post it up.
I agree, you should post your settings. Preferably a screenshot over a phone photo.
If you’re using grayscale, be aware of it’s use:
If you dither, your interval should be very close to the results of the damage produced on the weakest link. Spot size, itself, is a good starting place.
In other words, if your laser produces a 0.10mm spot size, but when it hits this type of wood, it makes a 0.20mm damage area, it’s not going to give you good results with 1/2 the required interval, as a start.
I have four lenses for the co2 machine. The spot size on the 2" is about 0.206mm. I have done 128dpi photos with pretty good results.
Start by using preview and understand how it works. It, basically, simulates the machines operation.
It’s clueless about
  • what machine you have, exactly
  • what power it’s capable of
  • lens length
  • spot size
  • type of material
All of this is very helpful for us.
Preview just shows you what the machine is going to do as far as movement and lasing. Enable show transversal moves shows you where it moves (red) without lasing. You can also zoom in on the preview screen.
Add to that you have a difficult image, it goes black to white with a small range of gray in between. This is a pretty long range of grays to contend with, even when dithered. I think you’re exceeding the actual gray range of the material.
I’d try increasing the interval to at least 0.20mm and see if that helps for a short term attempt.
Is this 12mm thick outdoor cd or just regular indoor finish plywood?
:grinning_cat:
