YDFLP-E-300-M7-M-R
SG7110 galvo head
I’m setting as per this:
I adjusted ton and toff and jump time. The test card responds, I got the Ton and Toff to meet the intersection with no extra burn, and I got the angled tick marks at the ends to disappear
However, the corners remain rounded. I added a very large number for Polygon TC and it has no effecf. I tried adding the large value in Layer->Override Timing Values, and also disabled the Layer Override and entered it in Machine Settings. Neither mattered. It’s like LightBurn isn’t implementing the value entered at all
Stranger still, the big square polygon in this test has a corner that stops short of the corner vertice in both X and Y. This is supposed to be controlled by Ton Toff. Ton=0 and Toff=250 got the line intersections to work perfectly, so this corner should be fixed, but it’s not. And if I do anything to change Ton/Toff then it will break the intersections.
