Not the best of the pictures, but you’ll get the idea.
Love the world clock, keep up the great work.
Gwyn Rhondda Valleys South Wales UK
Thanks for the compliment. I am starting to sell them in our local artisan shop. Renting a shelf is only £7/ month so if they don’t sell, I’m not going to lose a fortune, if they do, I’ll make some extra money on the side.
Bit off-topic; a simple desk clock for a change. I wanted it to have a kind of 1970s Soviet Union vibes.
4mm MFD only, no glue needed, cuts are tight enough to hold it together. Treated with water based stains and finished with acrylic lacquer. Hardest part: sanding the parts after staining them.
Little more elaborate design. The size is 42cm wide and 12cm deep. 4mm MFD and 2mm basswood. Painting and gluing the “arms” was fun ![]()
Very nice design choice and well executed.
Thanks. It is quite fun to make and looks gorgeous on the wall. The best thing is, material cost is very low, the cost comes from time spent to put it together. I’m taking it to the shop on Tuesday, going to be interesting to see if, or how quickly, it sells.
