Something happened to my travel speed
I am not sure how or what I did, but to get the laser to return to its origin at a decent speed, I had to increase the speed to 7000mm to get it to match the prior speed of 180mm. What did I do? If I change the 7000mm to 180mm the laser moves at a 180mm speed. HELP!!
Check that you’re working in the units you think you’re working. Is it possible that you were previously working in mm/s and now you’re working in mm/min?
Note that diode lasers typically are used in mm/min units.
berainlb- thank you for the reply. I think you are right. Where do I go to change back to mm/s?
Go to Edit->Settings and change units there.
You sir, are a lifesaver! Thank You!
