After installing version 1.4.04, all my projects changed their stored speed. in all the projects the velocity was from 100 to 800 mm/s, now they are almost all at 6.67 and in any case no one with the speed with which they were stored.
Thanks for your help. Italo
I’ve never seen LightBurn change the speed of a Cut Setting for an existing project. It’s possible that you’re using different units now than what you were previously.
Check Edit->Settings and make sure you’re using the expected units. I’m guessing you used to use mm/m and now you’re showing mm/s.
My God, you’re right. I changed PC and after installing Lightburn I forgot to import the preferences. In fact it was set to mm/s. I changed to mm/m and the speed returned as set. Thanks so much for the help. Greetings and Happy Holidays to everyone.
