Hi All, I have purchased a New Neje 40 Watt Max 2s laser. I have set it up and so far so good but I saw something last night that I was not sure of what was happening and I wondered if maybe I had not set it up correctly. I started a job (which actually successfully completed) and I noticed what is below in the console window. The job was set to run at 300MM/M, power 82, passes 9… The job only had 1 layer, but when I looked at the console window I saw this:
Starting stream
Layer Speed 50 mm/s Pass 1 of 9
Layer Speed 50 mm/s Pass 2 of 9
Layer Speed 50 mm/s Pass 3 of 9
Layer Speed 50 mm/s Pass 4 of 9
Layer Speed 50 mm/s Pass 5 of 9
Layer Speed 50 mm/s Pass 6 of 9
Layer Speed 50 mm/s Pass 7 of 9
Layer Speed 50 mm/s Pass 8 of 9
Layer Speed 50 mm/s Pass 9 of 9
if you convert 300mm/m to mm/s it = 5 not 50…can anyone tell me why I see 50? I checked my settings and I am using mm/min which is recommended for diode…
