I have run Lightburn succesfully using a 17 year old laptop. Typical feed speed for a particular job 900/80.
Downloaded a new Lightburn onto a new laptop. If I use the same 900/80 it will not make a line.
Have been down to 25/80 to get any result. Also this setting will not work on a similar job.and I have to play around with settings to get any result. It now takes me six times as long to finish a job. Any Clues?
Are your device settings the same from the old instance of LightBurn to the new one? In particular, an incorrect S value could cause be the culprit.
Also, your lens may need cleaning
