I’m not sure what I did this time however frame is barely working and speed is at .98 to cut.
If I go over 1.00 it just speeds to quickly.
Any suggestions?
You’ve specified units as inches per second. Go to Edit->Settings and change there.
Frame speed is determined by the speed setting for jogging in Move window.
These are the settings I have now.
Changing from mm/second to mm/minute in Settings may reduce confusion.
Click Edit in the top row then wheel all the way down to the gear icon and click Settings. In that pop up, half way down, Just off the left side select mm/min.
Then click the OK box at the bottom.
That will make the small speed number into a larger speed number without changing the speed. The units of the speed really foul people up.
I’m still trying to find a really easy way to share an intuitive grasp of speed units.
A bowling ball at 3 feet per minute is really slow and 3 feet per second is 60 times faster… it’s still ‘3’ but the units can matter more than the number does.
