Hello All,
I am writing 5 lines of text and a QR code on a 100x135mm plastic board, fill setting, and it takes 15 min on Neje Master 2, 3000mm/30% power.
Is this time expected? Is there a way to speed up the work?
Thanks for reading,
-Gian
Hello All,
Thanks for reading,
-Gian
I’d suggest increasing speed and power… double the speed and double the power.
This works fine until the overscan is larger than the work area, you loose time or you can’t increase power enough to keep them balanced.
This is the same size rectangle, left is 500mm/s, right is 1500mm/s … Notice the faster one has the longer job time.
May not be exact but it should be in the ball park…
Good luck
