Is it possible to speed up an engraving or change the number of passes while it is engraving? Or can that only be done before the engraving starts?
If you have a diode laser/ grbl machine, you can adjust the speed slightly using buttons you will see in the move window, while the project is running (the move window will change when the project is running). But there’s a limit of (I don’t remember right now) X%, it’s not endless.
