Split Beam on Diode
Interesting theory.!
when I do the next test I’m going to rotate the sheet to 45°. I’ll also try it with the test material that the manufacturer includes. Thank you my friend, all of this is really helpful.
I have to ask if you’re sure it’s glue?
This looks very similar to fiberglass. I see it when I laser FR4 pcb material. Even the fiber won’t cut through it. This hardly looks like it’s even scorched.
I’ve seen lots of glue area fail, but it always looks like it tried, except where it couldn’t.
It’s really difficult to tell from a photo.
:grinning_cat:
I was looking for the images I have of glue/resin in ply that wouldn’t cut without great effort but that image was the best I could find in the folder to do with what can be in the layers.
That unknown material would not cut or even mark with the laser and I had to physically break, twist and tare the piece apart to get the image. I found quite a bit of it in that sheet or sheets and it appeared to be a flat woven twine or strapping. I do remember that and the bad resin/glues were using up a lot of production time, I think it was about 25% of pieces were being thrown away…That was when Bernd advised about researching quality ply and such as Aeroplan for quality results…but at two to three times the price from Irish suppliers.
I actually thought buying precut online would be a better cost effective option or paying extra to purchase through a woodshop who could cut full sheets to various coaster or picture sizes so I would only have the engraving to deal with.
At that time I was just finding my feet in laser operating and it was pretty stressful dealing with that and all the other pitfalls that await a newbie. If the machine and software are solid and good materials are bought for the required pieces, then the mind is free to concentrate on learning the skills.
Now, I insist on only wrecking the very best natural slate!
I have found fiberglass woven belts 1/8" wide in my 3mm Baltic Birch plywood sheets. that was laser resistant too.
Here’s another couple of examples.
It’s probably Chinese packaging waste plywood, some of the worst crap you can get and definitely not meant to be used on a laser. Contains everything from floor sweeping, including plastic and even metal.
Friends, here’s an update on the problem I’ve been having with my machine. The manufacturer asked me to run tests with the new and the original head on the test material they include in the purchase package, which is a 3mm plywood. They told me to use the same cutting parameters for both, to record everything on video showing the serial number of both heads, and to send them photos of the lenses on each one.
When I first reported the issue, they recommended using the chart they sent me with the cutting and engraving parameters based on the machine model and the material. I did every test exactly as they requested and the result was the same: the machine cuts, but not completely, it only cuts in sections.
I used that same material for other tests before the failure happened and it cut perfectly at 50% power and 290 mm/m, I had no issues with those settings, but then the machine stopped working that way.
It’s at least nice that your supplier is trying to help you.
Your camera calibration mark looks the best if we talk about correct focus, but on the 4th number your min. power is not set correctly, the lines are broken at the ends.
“New/Old” text … is it single line font or is it made in fill, or have you just reduced focus?
Notice how the reverse side of the material shows the cut coming through when cutting with the grain but not when cutting across the grain.
I have never cut 3mm ply but in my limited experience, at only 50% power and 290mm/min that result would meet my expectations…But can you remind me what number of passes you used here.
Can anyone say if cutting performance is linear when raising power at a constant speed.
Yes my friend, as I mentioned before, the result is the same even when rotating the piece 90°, the machine is new and besides that it hasn’t been used constantly every day, and in the first tests the material cut perfectly even at 4mm with the same parameters…At first I thought it was the wood grain direction, that’s why I rotated the material, but the result is the same.
I even increased the power to 85% at the same speed and the result didn’t improve as I expected, on 4mm I even did 4 passes and the result still wasn’t optimal, it left small uncut bridges.
I would argue that nothing in this context is linear. In my tests (CO2 laser) the power curve is almost like a human productivity curve. A lot happens in the young years, in the forties and fifties you are close to the peak and at 70 it goes the other way again. :wink:
The speed also has an important role and can lead to a relatively wide power variation. That is, 10mm/s at 20% power can possibly be changed to 20mm/s at 50% power, but again, there is no linear curve or clear logical guidelines here either, as far as I have seen.
I would try to find a very “laser-friendly” material and do some comparison tests.
I have seen and worked with so many different plywoods and seen so much misery that I only work with “Aeroplan Plywood” - interior glued.
It is a fact that normal plywood, bought for example in the construction market, does not have uniform repeatability properties. You can be lucky in many cases, but the probability that you will have to discard a production due to bad material is high.
If you have a very powerful machine, it is not so critical, but here too the finished workpieces will have ugly edges if the “wrong” plywood or exterior glued material is used.
The material you see on top in the photos labeled “new” and “old” is the material the manufacturer sends for calibration and testing, it’s 3mm and in my opinion it’s very laser-friendly, but it still shows the same finish, it doesn’t cut completely where it used to, as for the age and usage of the machine, I can assure you that if I add up all the usage time it would hardly have 10 full hours of use.
If you are convinced that your machine is faulty…, try returning it or exchanging it for a new one.
Explain your problem, your systematic troubleshooting and appeal to their reputation :wink:
Hi Joshua
I went back to look at the spot on the wall test and apart from the slightly different shape of one of the dots (one half of the stacked 2 diode sets) the luminosity of both sides seems equal, so I assume we can say that all four diodes are working…still keeping in mind your initial supposition that the issue could be before the module (controller etc).
If there were an issue with the diodes or pre-diode electronics then the end result would surely be a reduced luminosity on one side or both of the output and the only way to know what’s actually happening is to measure the power to each diode and check the expected supply.
As bernd has said, the variations in material quality can be substantial and we must also remember that material used in the laboratory to rate these laser module abilities may be biased toward the optimal. The materials you receive from the suppliers may be far different in composition…if even the same type.
The bridging is definitely an indication of material variance, even if only because the machine cannot choose to vary it’s power delivery.
I definitely think a purchase of some uniform single type material will at the very least show the minimum settings requirements per task, Cut and repeat till 100% cut = Minimum power & Passes (If the material is raised above the cutting deck you can observe when the laser has cut through 100%), And light engraving/Marking to check consistency…looking for inconsistency that is worth noting.
As for the somewhat sudden drop in performance, I would expect the laser module to have a shorter than expected lifespan if faulty, and as you have already notified the company you have a legitimate claim for replacement that they may consider.
In the meantime some testing and comparing may find you happy enough to continue if your results compare well to results that others here on the forum have from comparable equipment.
Very interesting issue.
Have you run the machine with air assist turned off? The cover lens might be dirty or fogged, giving you a reduce output.
As far as that twin strip diode light pattern on the wall is concerned, unless you dropped the module that would not suddenly appear and give you reduced output.
If I’m following this correctly, the split beams are seen at a distance. The, at least to me, obviously it’s not aligned. If it’s not aligned on the ‘wall’ then it’s not aligned.
A lens only takes what it’s given and makes it smaller. The gap is still there after the lens, albeit much smaller.
It’s just doesn’t seem reasonable to have this pattern.
I think @bernd.dk has the best suggestion, send it back.
IMHO.
:grinning_cat:
