I’ve been burning a lot (already on 2nd laser module) and I haven’t run into this.
I’m burning keychains (3 layers). 1st layer is the image, 2nd layer is the keyring hole, 3rd is the square cut. I didn’t look in to see the keyring holes being burned, but I’m noticing on the square cut layer, it’s burning the 9 passes (cutting ply), then it goes to the opposite side of the square and burns another 9 passes. It’s burning twice as long as necessary. Is there a setting I’m missing? Is it the “Choose best direction” setting? I paused my burn (110 keychains) and turned that off, but no change when I resume, so I paused again to ask in here.
How can I change the passes in the middle of a burn? Will the Gcode pick up right where I’m at if I save it, or what do I need to do? Thank you so much in advance!
