This would work to artificially simulate the time between “Idle” and “done” but the red light would also be on any other time the yellow light is off, would it not… including startup and not running modes.
Well, I tried this… moved the wire to the red lamp over to the “AIR” pin, but had no luck. Yellow working correctly, but Red still not coming on, even with air assist on all layers in Lightburn.
My air pump (internal to the machine) is on any time the machine is powered on… it does not appear to need to be told by Lightburn to run. And there was never anything connected to any of the pins on that block (in fact, I had to buy the connector myself… Monport didn’t include one). And just for drill, I swapped the connector out with another, just to rule that out too.
Just to make sure my Red lamp was not the problem, I swapped the yellow and red leads, placing the red lamp where the yellow was… and it responds correctly. So it’s not the lamp.
Duh… so I went into the vendor settings (using RDWorks - which makes me hook up a USB cable… but I won’t go into that here) and toggled the “Blower” tick box to on (why they call it Wind in one instance, and Blower in another, is beyond me - might as well be Chinese too). Low and behold, with the red lamp wire on the wind sink, it does in fact light up the Red lamp when cutting a layer with air toggled on in Lightburn.
I almost want to call this a solution. Is there somewhere in the Vendor Settings that controls that Status sink maybe?
I’ll be damned… that little bugger right there is the reason my “Status” sink was never working!
I had seen this screen in an RDWorks video, but they never explained what it did. Apparently Monport in their vendor wisdom, decided to not enable this particular box… the result was no activity on the Status sink. Once I enabled it… EVERYTHING works as expected. There appears to be no equivalent setting in Lightburn.
I have no idea what the other toggles are for (colors, situations, etc…) but with simply “Enabling” this… it works.
Thank you all for your help and direction on this topic.
I can’t believe it was there the whole time.
